Looking some one can help welder for my waste oil project (motor oil) I have build a waste oil heaterworking fine give me lot off heat ,you can see pic but I go to build a big one any one who live near Stockport area manchester
the second picture looks like its been burnt through a heat exchanger with a flue so i wouldnt think soi'd be interested too
does it burn cleanly enough or does it give you a headache like a parafin one?
Ringo - thank you for sending me your 1 sheet design diagram but, to be honest, I can't understand it! The design seems quite simple, but the way it's sketched I simply can't understand it, specifically the retention head, the reference to 3mm x 10m, the row of holes, etc.
hi i have working on waste motor oil burner for over 2year its my design if you want i can sent you some my design give me your e-mail
I looked into making one of these, till I found the price of waste oil.
Anyways this is an interesting link,
http://www.green-trust.org/2000/biofuel/babington/default.htm
http://www.aipengineering.com/babington/Babington_Oil_Burner_HOWTO.html
Its a babbington burner, oil is poured around the side of a doorknob, yes doorknob, and a really small hole is drilled into the front of it, the shockwave caused by the airflow makes the oil into a fine spray and it burns away inside a tube, a good design as there is no jet to clog up only an air jet, I saw an article where some geyser had used a bike carb jet as bashing a tiny hole int easy.
I was going to use a power steering pump as the oil pump and an old fridge compressor as the air supply.
