I have an aqua blaster with an incoming air supply.
It has a check valve in it so if you operate it without the air connected, the water/glass bead doesnt back feed down the airline.
As you can see from the pic its a proper cheap and nasty affair. And totally useless too.
After dismantling the valve, solenoid valve and pressure reg for the umpteeth time to remove glass beads, its time i sorted out the check valve.
Does anyone have any suggestions/links to something that might work?
Apologies for the poor pictures. Looks like im working in a cave.
