Ali
- Cheshire
The linings are near the end of life, having about 2mm before rivet contact.
Glue the next ones on and get a bit more life
I wonder if you can still buy re-lining kits?, I remember watching my dad doing the linings on his SII Landy in the 70's, I think I still have some of the copper rivets he used.
My brother & I went to reline some shoes on his CA Bedford one Sunday when he was home, found the rivets were missing, the vehicle had to be got back on the road, so we pop riveted the linings on. Worked fine, outlasted the van from what I recall.I wonder if you can still buy re-lining kits?, I remember watching my dad doing the linings on his SII Landy in the 70's, I think I still have some of the copper rivets he used.
I believe it was done because if the drum was to large a dia it was possible for the brakes to actually run out of adjustment and you could potentially have no brakes.no need just run them till you hear metal on metal then you know you have had your moneys worth![]()
i re lined my twin leading shoe front brake on my norton . rubbed chalk on the ferodo linings and spun the wheel applying the brake a bit took it back out and filed the high spots off . did it 4 times till i got 95 percent coverageI believe it was done because if the drum was to large a dia it was possible for the brakes to actually run out of adjustment and you could potentially have no brakes.
We used to have matched drums and shoes machined as pairs due to brake issues at mot time.
Lots of drum brakes a work, we see lots of issues, bloody things are a right pita.
I just knew someone would take that bait. I therefore hereby unilaterally award myself: One Point.
You should have noted the £300 for each replacement to realise you had been led up the garden path by the coincidence of size.
Alvis TA21.
A very good year too - its DoB is almost exactly one month before mine. 13/11/51 versus 15/12/51
