Rannsachair
- Lochgilphead, Argyll, Republic of Scotland
I picked up this rusty very low profile 8" rotary table the other day.
Consensus appears to be it is likely a Tom Senior. Some original paint:
Was lucky to get every screw, bolt and set screw out intact some took the impact screw driver.
Stuck a few parts in the evaporust:
The sleeve next to the handle was seized to the shaft, so out with the torch:
The fixture plate was bolted and doweled on:
All apart, wire brushed and buffed up some of the smaller parts:
All looks not bad:
I put the calipers in the first pic in the evaporust then buffed them.
Seems to be no scale on the handwheel sleeve, not sure if corroded or there is a part missing:
Will need to do some research.
All looks not bad:
