Hi guys, I need to weld some vertical bars (16mm diameter) into a frame which is tilted 25 degrees from horizontal. I want the holes to be a reasonably tight fit, so no oversize holes & fill with weld.
What is the best way to drill the frame on the diagonal so the bars slot in at the correct angle. The frame is 40 x 10 flat.
I've done a piccy to explain. I know I could drill it straight and die-grind the hole to suit, but where's the fun in that? I have about 60 holes to do.
Anyone know if mag drill broaching cutters don't mind one side biting first? Or perhaps I should use a milling cutter? I figure anything with a pilot drill is out.
Cheers, Al.
Cheers, Al.
