It's no big deal as long as you're not trying to upgrade to Windows 11 (which you shouldn't!)A little red dot has appeared in the lower corner of my computer, I clicked on it and it states my PC is not Windows 11 compatible/won't upgrade. Is this a big deal or is there a way around it? Thanks in advance
Bob
Who's posted tin foil hat nonsense about Microsoft spying???Whats wrong with 11?
I installed it in my mini laptop and another one I use for basic tasks, I like it
(If you are going to post tin foil hat nonsense about Microsoft spying then also post proof, I will happily post proof it isn't true)
Microsoft are forcefully pushing 11 out (it's hard to avoid it if your hardware is suitable).
On the subject of compatibility the biggest reason for not being compatible is the requirement for a TPU. There are other CPU limits (mine technically isn't supported due to the age of the CPU but would run fine if not for the lack of TPU).
The taskbar.
The default browser and how complicated it is to swap to something else.
The bugs.
Runs fine on this, I ended up doing a reinstall and forgot to extract the key, however it was activated with my Microsoft account. The hardware serial port is full supported as well
Probably the machine does not have TPM Version 2.0. This seems to be the biggest issue with the upgrade checker.
Looks like Plasma KDE or one of the pretty distros...
Windows 11 with a nebula picture I like as a background
nobody has mentioned Apple yet.......hahaha.........
Who's posted tin foil hat nonsense about Microsoft spying???![]()
