For a 20 year life torch on system about £50 per m2 supplied and fitted on new build...£65-£80 on an existing old roof.With the current price of ply etc I would have thought the pre insulated box profile sheets would start to look competitive. @roofman How much does a flat roof cost these days?
Bob
We are ripping rubber roofs off very frequently because the glues have failed.Well just for balance, I'm a rubber roof fan. I did my first rubber roof last year and was pleasantly surprised at just how quick and easy it was - it was only a 12' x 8' apex shed, but I finished the main roof in an afternoon and finished off the edges the next morning. No bubbles in the rubber - I just rollered on a good coating of adhesive and then used a rubber roller to take out any creases. I could see if you were doing it on a hot day you would have to careful about the glue drying before you were ready to roll the sheet over but that would be my only minor concern. With a fifty year guarantee, I won't be the one putting in a claim!
Now you tell me! Though the adhesive that came from the rubber company was about £45 for five litres and looked a bit like PVA... I wouldnt be surprised if John Wayne and his chums were using PVA as a cheap substitute!We are ripping rubber roofs off very frequently because the glues have failed.
water basedNow you tell me! Though the adhesive that came from the rubber company was about £45 for five litres and looked a bit like PVA... I wouldnt be surprised if John Wayne and his chums were using PVA as a cheap substitute!
Especially if you buy from one of the seconds places - think my double garage roof is better insulated than the house at 100mm thick! Damaged sheets top and bottom of the pallet - rest were perfect. I was able to use the damaged ones too, by simply cutting the damaged side off.By the time you have bought insulation and decking it starts to make the £33 per square meter insulated box profile look very cheap. It would probably outlast any of the roof coverings.
40mm PIR Insulated Roof Panel – Anthracite Grey Polyester | FM Approved (1m Cover Width)Anthracite / 3.100m
Buy 40mm Anthracite Grey PIR insulated roof panels – FM approved, fire-rated, & in stock. Fast UK delivery, trade discounts, expert help available.www.colourcladprofiles.com
Bob
grp dosnt take long after the boards are down as you do it by sheets of rolled matting and mixed glueFood for thought, thanks all. For the GRP, does it all have to done in one go? Can you do the drip edges one day, go back and do 1 half of the roof covering the next etc then topcoat all together?
I’m quite happy to have a go at either options, but knowing I could break it down into stages would ease the pressure.
