That sounds great. Bet you are pleased!Looks like I have scored a regular supply of logs for my boiler. Its pine so no good for the stoves but perfect for the boiler as it gasifies all the resins. It's from a neighbour who manages some woodland a couple of valleys away. He will bring it back on a trailer on his way back home so in terms of transport, almost sod all carbon footprint. He reckons each trailer load would be equivalent to about 2 IBC cages worth of split logs, but we will judge that when he delivers the first load. I should be able to cover about 80% of my biomass boiler requirements this way. He will give me a final cost once we know we know how much timber is on a trailer but looking like around £60 an IBC worth. I will cut and split it, the boiler takes Eurolog lengths, 500mm long so easy to stack and quicker to load the boiler. My splitter has just about a 500mm throat so will probably cut the logs 450mm long to make sure.
It will probably be a bit damp for this coming winter but that's fine. I have a moisture meter and if its still damp I can continue to use pellets, I'll still be working so not able to load the boiler up every morning so its the year after I'm mainly interested in. I'll have to work out how to make sure its BSL registered for RHI, this probably means myself or my neighbour registering to become a self supplier which costs a couple of hundred quid, I think.
if it works out it will save me quite a lot and keep me fitThat sounds great. Bet you are pleased!
I am so lucky to get free wood.Looks like I have scored a regular supply of logs for my boiler. Its pine so no good for the stoves but perfect for the boiler as it gasifies all the resins. It's from a neighbour who manages some woodland a couple of valleys away. He will bring it back on a trailer on his way back home so in terms of transport, almost sod all carbon footprint. He reckons each trailer load would be equivalent to about 2 IBC cages worth of split logs, but we will judge that when he delivers the first load. I should be able to cover about 80% of my biomass boiler requirements this way. He will give me a final cost once we know we know how much timber is on a trailer but looking like around £60 an IBC worth. I will cut and split it, the boiler takes Eurolog lengths, 500mm long so easy to stack and quicker to load the boiler. My splitter has just about a 500mm throat so will probably cut the logs 450mm long to make sure.
Are you sure that table's strong enough for all that wood?I am so lucky to get free wood.
Even in a well insulated house I use a lot.
This lasts about 10 days with the AGA running the other end of the house.
I have to make 2 or 3 cuts per length.
Mix of soft and hard woods bone dry.View attachment 340885
I wishAn aga? That's posh!
Surely you employ a trusted family retainer to cut it for you?
It only weighs 800kgAre you sure that table's strong enough for all that wood?
I like the foot pedal on the chopsaw.
till your half a sleep and your fingers are in it!The problem with the chopsaw is there is no little button to lock the trigger. Gets very painful. Cable tied the trigger and use the foot switch. It's great.
If you look I have an extension pole on the handle. Treat it with the utmost respect!till your half a sleep and your fingers are in it!
Or an asteroid caves your head in, when you're not lookingtill your half a sleep and your fingers are in it!
I was merely pointing out a potential of which I am sure you are aware. But as your on buisness premissis, should the unfortunate happen to someone other than you, I suspect one of Parms collegues may insert one of those bits of wood into your rectum metaphorically speaking!If you look I have an extension pole on the handle. Treat it with the utmost respect!
Only done on weekends when no staff present. And outside as well. Too much mess otherwise.I was merely pointing out a potential of which I am sure you are aware. But as your on buisness premissis, should the unfortunate happen to someone other than you, I suspect one of Parms collegues may insert one of those bits of wood into your rectum metaphorically speaking!
You would probably prefer the random asteroid option.
ArghI was merely pointing out a potential of which I am sure you are aware. But as your on buisness premissis, should the unfortunate happen to someone other than you, I suspect one of Parms collegues may insert one of those bits of wood into your rectum metaphorically speaking!
Sadly though he is right.
One could argue that with the onset of vastly improved Elf and Safety has aided the reduction in common sense. As many seem to think its someone else's role to look after them and tell them what do, do so they dont get hurt.Sadly though he is right.
Elf and safety is rife these days. Common sense vanished a long time ago.
Just Ask @Parm on that front,Sadly though he is right.
But !
Sometimes you have to think outside the box, for one's self
