sako243
- My mansion in Wales
I'm slightly surprised you still know where they are!
i have a set of those. i only use them on on 1.5 mm lighting twin and earth thats loose out of the ceiling there no use for stripping cables in socket or light switch boxes as u cant get them to strip far enough back i normaly use knipex side cutters for thatI have the CK ones at a similar price , I'm impressed with the range of sizes , specially the smaller data cables it manages to strip.
They don't use a blade like some clones , it's purely a tension pulling operation.
I've been using them for a while (not every day tool but regular) and they seem to be doing well.
C.K Automatic Wire Stripper
Save time while working on electrical tasks using the C.K Automatic Wire Stripper. This versatile product is suitable for stripping both flat and round cables and wires. All it takes is two clicks to remove the outer sheath, as well as extracting the inner conductors in a cable.The tool is...www.toolstation.com
only down side's
Some 2.5mm flex its a struggle to fit the sheath in it.
If the cable insulation is old and "shinny", they sometimes struggle with it
The ruberised tough flex , it doesn't always strip the same length as the insulation stretches.
Sometimes a piece of insulation gets stuck in the mechanism and you have to pull thinking face to figure out whats going on.
Stu
only down side's
Stu
Look almost Identical, interesting.I have the Stanley version of these but it would appear they come with none of the downsides you mentioned...they just work, perfectly.
Do you use the length stop ? I think that might make the sheath jamming more common.
Stu
Jokari do some excellent gear - I had a wire stripper for larger cables made by them, it was very good.I've had this for 3-4 years now and it's been great
only down side's
Stu
I think these are all the same, I have ck ones and bought a friend Magnusson ones no difference other than the handles. But CK were 2x the priceFor general DIY - mains, lighting, automotive - I've found a pair of these to be rather good:
And like most Aldi stuff, I bought a spare for when it bust . . . spare still in the packet after a few years.
I have a pair of very similar design with less plastic strapped around them, and they do sometimes fail to reset the cable gripper - a quick flick with a finger and go to go again.
Another vote for the RS strippers, I'm on my third set after wearing the others out, probably stripped 10's of thousands of wires while panel building.
I use these exclusively, I'd resisted after all real men just use shears it's a tool I love.
I had to strip a pvc cable on a truck now with a knife and shears I'd almost certainly damage the inner wires, the sheeth had gone horrible tough perished the way it does, these did the job with no complaint
The blades can be replaced on these too which is a plusI picked a couple of broken wire strippers up for a quid each and made one good one out of the two. It's an Ideal Stripmaster and I've been using it for years now, it works perfectly on any gauge I use.
