Hello, NFT or non fungible token. What are they? What do they mean? Can I weld them?
Is my ignorance bliss in this case?
Turn the next page and forget you ever read or mentioned them...when you need a few quid and you have it to spend then you will thank meHello, NFT or non fungible token. What are they? What do they mean? Can I weld them?
Can I weld them?
I agree with you, up to a point.My understanding;
Same principle as art. But digital.
You can own a bit of art but it's only worth something if someone else thinks it's worth something. It has virtually no intrinsic value you can't eat it or make a useful tool out of it. Best compared to a modern or conceptual art piece; a lot of these objects are totally replacable or replicatable but their value is because someone specifically had the idea at a certain time Duchamp's urinal, a classic example.
I don't see that I'm afraid.Same principle as art. But digital.
Sounds a bit like apple "I tunes" for posh peopleRubbish. A token that is essentially a recipt for a thing that can not be owned, another way of getting money out of idiots with too much..
I believe that's the point of NFTs - they ARE an original and never-replicated set of algorithms/codes, which may move from digital space to space, but never to be copied.I don't see that I'm afraid.
As an example, an original painting will be a one of a kind original and remain that. An NFT will never be the original as data is moved and backed up so no more original than a copy or a million copies, they are all identical as it's digital.
