outofthefire
I was told new mdf is flat, not sure how flat in the grand scheme of things, but definitely flatter than my or my lathes accuracy
I was told new mdf is flat, not sure how flat in the grand scheme of things, but definitely flatter than my or my lathes accuracy![]()
There's a little more to it than that, but yes three square plates can be done that way.My understanding is that you start with three flattish plates, cycle them appropriately as you lap them in sequence and by the magic of geometry, eventually, they all become perfectly flat.
Same size yes.Do you mean that they have to be all the same size square, Brad?
Certainly round glass blanks for telescope mirrors would be the same diameter.
The only sensible answer by a long shotLike Pete says it depends what you want to do. I have both granite (used in the kitchen as a trivet) and cast iron surface plate in the workshop. Neither are calibrated flat, even have a few dents n dings, both perfectly acceptable for the type of home Bodgery I do. At a push I guess a decent granite tile will be good enough for home bodgery
Steady old chap. Me and sensible very rarely go in the sane sentenceThe only sensible answer by a long shot
I bought a small slab of marble from a salvage yard - old gravestone stuff. Incredible just how flat it is.
Not quite surface table league but not far off. Cost me £10!
Rectangle doesn’t work because you can’t spot corners when you turn the plates 90°Same size yes.
Round works too.
Rectangles don't work, because the overhang causes Issues
Granite Surface Plate is the term you want to search fofHi all, in various YouTube videos, people use flat stones as work surfaces. Does it need to be a special type of cut, or can I just buy a polished granite tile from a marble shop or stonecutter? Not sure what the trade is called in English. Thanks for your help!
