Retireddiy1
New Member
- Treswell Retford
When you see [Must be hardwired} written in the machine specs does this mean that the power wire from the machine as to go directly into a wall mounted socket ie no plug, or does it mean it can have a 13amp plug but you must not use a extension lead.
Cheers
Please note that details and specifications contained herein, are correct at the time of publishing. We reserve the right to change specifications at any time without prior notice.
Cheers
Technical specification
| No Gas/Gas | Dual |
| Min/Max Amps | 30/150 |
| Mild Steel Capability | 5 mm |
| Welding Wire Sizes | 0.6-0.9 mm |
| Amps at 60% Duty | 62 |
| Input Voltage | 230 V |
| Open Circuit Voltage | 21-32 |
| Power Supply | Requires Hard Wiring |
