larry boucher
New Member
- CA, USA
My hzxvogen 185ii feeds, but does not arc or arcs, but does not feed. How do I get it to do both? My very first MIG welder
Below is what they told me about the mig250dpWhen you use it in MMA or TIG mode the wire speed knob is used to control the current, it does not control the wire speed, no matter what you have connected to it.
When you use it in MIG/MAG mode the left knob controls the welding voltage (power) and the right knob controls the wire feed speed.
Does spool mean feed wire?I am not using gas. I got a different model earlier and it did the same thing. When it is on mma (picture of stick) the flux core arcs, but does not spool the wire. On CO2, Mix 0.8, & 1.0 it spools, but does not arc. Then on Tig it arcs , but does not spool (see photo). 2 different machines can't possibly have the same problem, can they?
