Welder: Clarke's 130EN (Polarity set for gas)
weldingTip: Drilled a bit larger.
Welding: 1/8" practice sheet (anodized coating removed)
Problem: Setting MIG for aluminum welding
Hey guys,
Ok, well recently i bought my cylinder filled with argon-shield gas. Now, I hooked it up, fed it the aluminum 4043 .030 wire. Turned on the gas to about 5L/m(Too low?) set it on the low setting and wire feed to about 5/10. Now when i started to weld, all it did was blob up at the tip, then tangle. 5/10 is where i have had it for every attempt. I have tried 1-3/4 heat settings, gas up to 13L/m. I have had it to crack and buzz, but it seems not to give me a somewhat decent weld.
I've read most/some of the aluminum threads and i guess what i am doing wrong is gas is too low and speed is to low? Now i read that someone has their gas setup at 16L/m and wire feed at around 8/10?
Would this be correct?
I do not have the nylon liner, however it does not seem to tangle up anymore since i drilled the tip but still blobs up.
Any advice would be greatly appreciated.
Thanks in advance,
~Dez Williamz
Hey guys,
Thanks in advance,
~Dez Williamz
