Wired itJust wire in on the 3phases, if it spins in the wrong rotation swap over 2 phases
Swap any 2 phases, it doesn’t matter which ones .Wired it
(BrownL1,BlackL2,BlueL3) and it ran in reverse, which 2 phases would I need to swap? Unsure weather it's star or delta either, or if that even makes a difference
Thanks, will give it a try in the amSwap any 2 phases, it doesn’t matter which ones .
As it is 3wire without a neutral it is delta.
No 3 phase motors require a neutral - it’s 10hp so it may well be star/delta for startingIt ran without a neutral connection, makes it delta!No 3 phase motors require a neutral - it’s 10hp so it may well be star/delta for starting
I fear you are confusing a transformer connection and a motor connection. Just for clarity - a 3 phase motor whether star or delta does NOT need a neutral so the lack of neutral is no way to identify how the motor should be connected - you can only determine that from the data plate and supply voltage.From the system perspective if there is no neutral it is a delta connected load as there can be no neutral current.
3phase balanced loads have no neutral current whether they have a neutral connection or not is irrelevant. Just removing a neutral will not magically balance a load.3phase balanced loads do not have a neutral
Probably easier if you show us a picture of a 3 phase motor with a neutral connection…I’ve never seen one but am happy to be corrected.3phase balanced loads have no neutral current whether they have a neutral connection or not is irrelevant. Just removing a neutral will not magically balance a load.
In aircraft where neutral point of both generator and motor are taken to the airframe, less so in modern designs as most are now run from motor drive electronics.Probably easier if you show us a picture of a 3 phase motor with a neutral connection…I’ve never seen one but am happy to be corrected.
In your ”star“ internal configuration if there is a shorted winding where do the fault currents flow?
I’m guessing the OP doesn’t have one of those on his compressorIn aircraft where neutral point of both generator and motor are taken to the airframe, less so in modern designs as most are now run from motor drive electronics.
