MysterG
- Wiltshire, UK
Yeah, the golf does that too. That's the sensor I mentioned about disconnecting a few posts up above. The tweak to the ECU code I mentioned actually changes the parameters for the stop start to be active. It raises the minimum acceptable voltage up to a point above what the battery can put out. Trouble is that this means it's totally disabled unless you get the ECU RE reprogrammed again, and as far as I know, it seen as emissions control tampering, and is subsequently an MOT failure.
But it can't be the same as the Fiesta. During all the lockdowns we hardly used the car and due to that the battery was low and the stop start did not active for months. It was only after a hundred miles or so journey it started working again.
If yours is flatting the battery surely something must be at fault?
We've been back to short journeys for months and again it does not stop/start..
