Brian250357
In my search for a suitable mig welder I've come across this Wolf one.
Does anyone have any experience of this model or any comments about it.
It seems to be a reasonable spec, for my needs at least and seems good value for money at £139.99 inc VAT.
Kind regards
Brian
Details below:
www.ukhs.tv/Automotive/Welders/Mig-140-Welder-With-Kit
Introducing the new Wolf 140 Turbo Fan cooled Combination Gas/No Gas MIG Welder. With so many features, this smooth DC output welder offers both gas and no gas MIG welding, and is easily interchangeable between the two. With simple polarity changing (requiring no tools), makes this welder such a simple and quick way to convert this high performance MIG Welder! Supplied with all the accessories needed to start gas or no gas welding MIG welding, this new MIG welder with its non live torch is a pleasure to use.
Incorporating 6 selectable power output settings, you can select the best setting for the job in hand, whilst the welding current range can be set from 30 amps to 135 amps. With fully variable wire speed control, you can adjust the wire speed to suit precisely the job in hand.. You’ll not fail to be impressed with the performance of this machine. If you’ve never had a DC output welder, you’ve never experienced just how straight forward obtaining good welding results can be. The inbuilt turbo fan cooling cool allows for extended welding duty cycles and with the transformer thermal overload protection circuitry.
Technical Specification:
• Turbo fan cooled
• 30 amps-135 amps welding current range
• 6 selectable power settings
• Smooth DC output current
• Non live torch
• Weight: 32Kg
• Fully portable
• Operates from a 230V single phase supply
GET ALL OF THIS
• 1 x Mini spool of flux cored MIG wire
• 1 x Mini spool of 0.6mm mild steel copper coated MIG wire
• 2 x 0.6mm tips
• 2 x 0.8mm tips
• 1 x spare 0.9mm MIG tip
• 1 x spare torch shroud
• 1 x 0.6mm / 0.8mm wire drive roller
• 1 x Gas cylinder of CO2 gas
• 1 x mini gas regulator
• 1 x chipping hammer/wire brush
• 1 x hand held face shield
Kind regards
Brian
Details below:
• Turbo fan cooled
• Non live torch
• Weight: 32Kg
• Fully portable
GET ALL OF THIS
• 2 x 0.6mm tips
• 2 x 0.8mm tips
