Battery boxWhat is it?
Coat rack finished, apart from making 20 odd hooks, that’s the last time I’ll see it now.
Spot the mistake?
Good effort, I bet the cost of material was similar to buying ones off the shelfWhile messing about with melter I did a round tuit on lathe and made up 6 pins for dinse 10-25 plugs to be brazed on. Then stuck the 3 I can find with silver solder.
I dont have any original 10-25's so not sure what size the pin should be turned to, 4 or 5mm square is probably ok.
One legged races?I only ever see single shoes at the side of the road.
Don't weld it on with the magnet in placeNow that the crap weather has passed I was able to do a bit. Got the shoots done. Made a start on the handles.
View attachment 334330 View attachment 334331 View attachment 334332
are all the chamfers done by hand? The way everything lines up next to that g clamp is almost pornographicMagnet is just to hold it in place so I can step back to get a visual. Everything is done by hand. All I use is a 0.8 cutting disc. Flap wheel and files.Don't weld it on with the magnet in placeare all the chamfers done by hand? The way everything lines up next to that g clamp is almost pornographic
Top notch work as alwaysMagnet is just to hold it in place so I can step back to get a visual. Everything is done by hand. All I use is a 0.8 cutting disc. Flap wheel and files.
Thanks cuthy.Top notch work as always![]()
I don't comment often on this page,Today I made a set of forms for making 100mm long louvers.
All made out of scrap using various grinders.
Started by cutting a bit of 10mm plate to size with a 4.5 inch grinder then shaping it with a flap discs.
Then squared an edge on an off-cut of 25mm plate, marked the rough shape and made a few cuts with a slitting disc.
Ground the middle out with a 4 inch and did the corners with a 2 inch grinder
FInished off the shaping with a die grinder.
Then tack welded a short piece of 5mm x 25 flat to close off the end of the die. This would probably be better if it was 25 square bar but it will do for a test.
And tacked a bit of heavy flat bar to the other form.
Cut a slot in a bit of scrap and tried it out.
I need to be a bit more particular in cutting the slot and clean up the sharp edges but it seems to work ok.
But this is worth commenting on,
Brilliant, time consuming, top work.
but I did have one for the Beaver NC5 that looks to be a home made one, a decent one though and it had been properly hardened.
