anyone have experience with resin tower water softeners?
I've got one of these.... inline before my water heaters at work but it's not doing enough, need to investigate more but pretty sure my boilers are scaled up (2x 50kw inline gas water heaters)
so I need to sort out better water treatment, it's a hard water area, and we use a lot of hot (80'C) water
with the resin tower ones, you get a rein tower the water flows through, which softens the water, then set by timer the system reverse flushes itself with salt water to clean the resin.... salt water comes from a tank full of salt
but... how is the salt water pulled into the resin tower? it is just sucked in via venturi and the output is constantly dumped down the drain?
we use a lot of hot water so an off the shelf system is £ thousands... so figure I'll go with ebay first, parallel up some big resin towers... just need a way to control them all
would be easier to dump their controls, add some 3 way valves and pump the salt water through them?
the two chambers were in a dustbin sized enclosure and a second one being for salt for the brine. Changeover was a simple toggle valve driven by the turbine.
