123hotchef
- Kent
I have decided to make the saw coolant tank from plastic as it was free.
I need to drill a hole and make the outlet feed to the filter then the pump.
Just thinking what kind of conector to use?
Normally I would drill an use a tank connector.
This tank will have neat cutting oil in it.
Should I drill the outlet above the fluid level and have a elbow in the tank to avoid any leaks instead?
I know you need pictures!
