Jeepers, why not just put the disc in the vice, hammer and pin punch, bin the disc?Got a nice rount tuit this evening:
My wire EDM hasn't materialised yet so I did it the old fashioned way, with square drill bits.
I've had a disc stuck on my 9" grinder for about two years, I very rarely use it but when I do it's cutting concrete, with water to keep the dust down, so no wonder it seized. Bent the original spanner, couldn't get a good hold with mole grips and a punch and hammer was too awkward do while holding the spindle lock.
Spun it off in seconds.![]()
Yep, hard work in en24t.You filed the square hole out then?
Didn't think of it.Jeepers, why not just put the disc in the vice, hammer and pin punch, bin the disc?
Fjr1300 engine into Slag
I did not let a heavy shower stop me. Waterproofing has been considered! I did add a weighted tarp after... It was starting to glow and just as I was about to add metal in the pot.
I did intend to add another two peices 500g worth, but for some unexplained reason the house RCD tripped, but then was fine after resettingLandlord was not happy, even though it was only off 20 seconds.
Fell out the tube nicely, quite happy with the result. Plan to turn this first, and might cross section to get an idea of porosity.
I've just put the nut in the vice and rotated the grinderJeepers, why not just put the disc in the vice, hammer and pin punch, bin the disc?
You need swinging from the rafters by a rope tied to your 80ll0cks for that crimeFjr1300 engine into Slag
A pile of segments rolled for @grim_d .View attachment 331630
Should have sent it to me. I already have an EDM diesinker electrode that I made for 1/2” drive sockets !Yep, hard work in en24t.
Didn't think of it.![]()
Becoming tedious parking the digger,then walking back to gather tools,so I made a rack.
I’ll add it to the next galvanising trip.View attachment 331462View attachment 331463
Rolled 1m bars,then cut.Did you do these individually? How did make sure the ends aren't flat?
Or did you roll over length then cut down
I was intending to try brass tomorow. I want to see what this can do incase it fails, I'll know what needs to be redesigned. Power is no problem, unsure about the element life and how well it is retained.When you've perfected casting brass I'll have a commission for you. Hopefully I'll be able to supply a suitable mould...
I have about 5kg of old taps and fittings, old gas regulator and about 1kg of swarf. The taps were chromed which may be a problem, would I be left with a chrome /nickel shell to fish out, or would it disolve into the melt?What are you intending using, plumbing fittings?
