rosinante
- Cornwall England
Hi All I have a job on at work where I will have to weld a fan nozzle to a plate in the back of a vacuum furnace[ the fan is 320HP
] and the nozzle guides the gas into the impeller from the heat exchanger,the nozzle is 400mm dia spun from mid steel and when centralised will have to be welded to a 10mm thick backplane,I have an inverter type stick welder,Q what rod/current should I use?I should mention that 40%of the existing weld stiches have failed allowing the impeller to foul--- 4 man days labour to access the motor/nozzle so I want to get it right,next Q should I start the arc on the thick part and weave on and off of the thinner part or vice versa, as is pretty obvious I am not a pro welder just the only fitter they have got!!
The pressure is a little daunting as the consequences of it failing can be pretty catastrophic and expensive,thanks for reading
Heres hoping
Cheers
Chris
] and the nozzle guides the gas into the impeller from the heat exchanger,the nozzle is 400mm dia spun from mid steel and when centralised will have to be welded to a 10mm thick backplane,I have an inverter type stick welder,Q what rod/current should I use?I should mention that 40%of the existing weld stiches have failed allowing the impeller to foul--- 4 man days labour to access the motor/nozzle so I want to get it right,next Q should I start the arc on the thick part and weave on and off of the thinner part or vice versa, as is pretty obvious I am not a pro welder just the only fitter they have got!!The pressure is a little daunting as the consequences of it failing can be pretty catastrophic and expensive,thanks for reading
Heres hoping
Cheers
Chris
