In that case, it's very likely that the torch has a gas valve in it - the other SIP gas versions use a mechanical valve in the torch rather than a solenoid valve in the machine. If that is the case, you only need to feed gas to the pipe via a regulator and, as Graham says, find a way to swap the polarity to the torch and earth lead.It does have the tube in the torch for the gas
