123hotchef
- Kent
these say magnetic scales
Just a Clarke CL500. Had it for years, and does most things I need from a manual lathe.
what lathe do you have?
Personally I prefer optical scales, but they need mounted so they won't get contaminated.
Told you...Looks like vevor are all out of 3 axis DROs but still showin a two axis. I might have a punt.
These might be a bit long for the Boxford at 10" and 40"![]()
VEVOR CNC 2 Axis Digital Readout Scale 5 µm DRO Linear Scale For Mill Lathe Machine | VEVOR UK
Discover CNC 2 Axis Digital Readout Scale 5 µm DRO Linear Scale For Mill Lathe Machine, Durable Construction and Low-energy LED Screen at lowest price, 2days delivery, 30days returns.www.vevor.co.uk
I was looking on there also
I’ve got them allTold you...
If you’re very carefulCan these be cut down if they turn out to be too long?
great I am off to order the 2 axis kit then thanks.If you’re very careful
oh do they I must look harder then.They do other lengths
Tail stock, I did get a 200mm i could use for the cross slide but I will probably fit a proper DRO one day to the latheFor what the cross slide or the tailstock
