Other Daniel
- France, Charente
Chuff me. You lot way overthink simple grunt & crack on jobs.![]()
A classic mountain from a molehill.
It's a shame your not closer to Salisbury, iam sure there are a few locals still about who know about moving stone.
not only heavy work virtually any jobChuff me. You lot way overthink simple grunt & crack on jobs.![]()
It so when it rains the blood washes awayThere was a similar stone table in several of the houses I lived in when at Bradford Uni.
We assumed they were sacrifical alters. I assume in these enlightened times you can appease the gods outside?
Apart from the teeth, apparently.You're always gonna have problems lifting a body in one piece. Apparently the best thing to do is cut the corpse into six pieces. Then I hear the best thing to do is feed them to pigs...
That must be a Victorian fluro light, then.![]()
Butcher’s cellar discovered under Dodworth shop
A TRADITIONAL butcher’s cellar has been discovered underneath a Dodworth shop where renovation works are taking place.Th... Local News News Barnsley South Yorkshirewww.barnsleychronicle.com
That's how I got my 65" telly up the stairs. Still in its box, just in case.I'm leaning more and more to the 'one step at a time' approach
I did consider that, but the amount of disruption involved would be enormous. Plus I'm not convinced the floor would support the weight of crane + slab, and I'm not keen to find out.Lift the floorboards above it, hire a small UNIC crane, ensure floor is sturdy enough to support it and lift it through the joists, pull the riggers in and drive it out on the UNIC.
Most difficult part would be starting it up and leaving it on autorun.
how do you think we fit steel girders in on wood flooringI did consider that, but the amount of disruption involved would be enormous. Plus I'm not convinced the floor would support the weight of crane + slab, and I'm not keen to find out.
its use of acrows and beam lifts first pic alone the steel beam is sat on the lifts and 2nd pic shows why
View attachment 330574View attachment 330575
] and building a central supporting pier in the end location. Then drill and peg the halves back together along with resin in the joint. Properly done, I reckon the joint would be almost invisible once weathered in. Should render it doable with less manpower?
Still not keen, but must admit it is a viable (and easier) solution. If (for whatever reason) getting it up the stairs in one piece is not possible, it's a plan B.Maybe the room/area above is carpeted and chock-a-block with furniture?
I'd be looking at cutting it in half [I know @mangocrazy doesn't want to, but sometimes 'needs must'] and building a central supporting pier in the end location. Then drill and peg the halves back together along with resin in the joint. Properly done, I reckon the joint would be almost invisible once weathered in. Should render it doable with less manpower?
I'd get the stone out before building a base / plinth in case it cracks in handling.Good idea about contacting people who specialise in removals and moving heavy objects. You've summed up the difficulties very accurately. I'm leaning more and more to the 'one step at a time' approach as well. I'm not ready to try moving it yet, as I want to to take it out of the cellar and lay it in its intended resting place in one sequence, and that resting place isn't built yet. I intend to use it as a garden table top, sat on a brick plinth.
Sorry to raise everyone's interest prematurely, but it will be a few months yet.
Plan A should be to buy a stone elsewhere. This is going to cost more than it's worth.Still not keen, but must admit it is a viable (and easier) solution. If (for whatever reason) getting it up the stairs in one piece is not possible, it's a plan B.
Nah. The only reason I'm doing this is because I already have it. And have you recently priced up stone slabs of this size?Plan A should be to buy a stone elsewhere. This is going to cost more than it's worth.
If it cracks it will get used as paving and I'll cast a concrete slab for the table top.I'd get the stone out before building a base / plinth in case it cracks in handling.
Patience, grasshopper...I'm beginning to think the stone will be in the same place long after the house has gone![]()
