can you not just use a metal tub for the anodising, inside another tub?
keep tossing ice in the outside tub.... inside tub a bit taller than outside tub so water can't get into inside tub
as the ice melts the water will run away?
that way you can really pile the ice up.... if the outside tub is big enough you can just freeze buckets of water for giant ice cubes? (I used to do that years ago water-cooling a pc)
