Same here.I have a Wolf Garten set on a long extending pole, I also have a pruning saw which replaces the pruner on the end of of the pole to cut stuff bigger than the pruner can manage.
Same here. I've been really impressed by the loppers and saw.
Yes Wolf Garten is very good homeowner kit.I have a Wolf Garten set on a long extending pole, I also have a pruning saw which replaces the pruner on the end of of the pole to cut stuff bigger than the pruner can manage.
I use a True Temper Ground Master extendable pole, with pruning saw blade and a rope-operated secateur type lopper. It doesn't seem to be available for sale any longer. It can get a little wobbly when manouevring it at maximum extension, but not too bad. If the branch moves when using the saw, the inertia of the tree can be put to good use, with short quick strokes....of the saw blade!!!from my reference of lifting long wood latts and other wood of 4m whats it like getting that pole where it needs to be
i presume the branch needs to be stable for a good cut with the saw
im asking as new neighbour seems to want to grow high trees by the look of it
as im needing pruners as well as a saw too go through good size branches that will be going over the boundary
Depends if there's a hornets nest at the end or not as my father once had - didn't want to be anywhere near it when the dead branch came down so decided the rifle from the end of the garden was a more satisfactory approach.
He's resting it on wood chippings!! ;-)Angel always trying to impersonate Miley Cyrus...
Should give your guy with the saw a kick putting the chain in the dirt![]()
.243 rifle rounds...
(other guns may be suitable as well)
