It would need to be leaking after the valve as the line between gauge and welder holds pressure overnight, going to see if I can borrow another bottle and a gauge although I'll have to wait until Sunday I have my doubts it's that either, my gauges in work are smashed I go more by sound of gas and tungsten condition plus the line between the welder and gauges leaks bad, I'll have a go on stainless today and see how that looksHave you got proper leak detector spray? Check your gas connection and pipework inside the machine.
Yeah it might be leaking after the solenoid.It would need to be leaking after the valve as the line between gauge and welder holds pressure overnight, going to see if I can borrow another bottle and a gauge although I'll have to wait until Sunday I have my doubts it's that either, my gauges in work are smashed I go more by sound of gas and tungsten condition plus the line between the welder and gauges leaks bad, I'll have a go on stainless today and see how that looks
Always use quality consumables. Saves time and money in the long run.What kind of torch consumables are you using? I won’t mention any names but we have experienced some problems with gas coverage when using unbranded gas lenses. Issue goes away when we swap back to Binzel, Parweld or CK.
We found the brass outer on the gas lens to be much thicker on the no name brand lenses leaving a much lower surface area of the mesh. I’m not sure if that is what causes the turbulence but it was the only difference we could see between the lenses giving problems and the ones that were fine.
That's not a good way to gauge gas flow at all! Get your regulator sorted, get a peashooter flowmeter at the regulator end, and a peashooter to measure flow at the torch, and then decide what the problem is!my gauges in work are smashed I go more by sound of gas and tungsten condition
Yeah that 2nd pic is what I'd expect to see on any TIG gas setup. But like I say, you still want a torch peashooter, they're only a few quid on amazon, and even if the scale is way off, you can dial it in to what you know works best and make your own repeatable setpoint.
Is that a 240v to 110v socket flying lead?![]()
Yes I've been meaning to build an extension to my garage for over a year that will have 16amp and 32 amp sockets
Tried it without it View attachment 328901
It's a commando plug colour of the outer wire is erelevant as long as its got 2.5mm cable if you think that's bad I worked in a place with what looked like pre war 3 phase sockets that could not be unplugged as the inners fell out when you did, I've welded lying in sewer water while it's been raining with my 240v welder sitting on a pallet beside me, I've had to do some dodgy **** over the years most times it involved cranes,Can i ask, what are you using 110v sockets for when they are being powered by 240v?! That's a really dodgy setup.
Damn. Really thought I had it sussed then. I tracked a gas shielding issue back to one of those cheap oxygen splitters for a customer.Tried it without it View attachment 328901 I also tried it without any peashooter
