Alan Reynolds
I moved 31 paving slabs at 72kg each on my own. I’m 74 and only weigh 70kg but loaded my van, unloaded it and moved them through the house. So two. People will move your slab easily.
Thanks, that's encouraging to hear.I moved 31 paving slabs at 72kg each on my own. I’m 74 and only weigh 70kg but loaded my van, unloaded it and moved them through the house. So two. People will move your slab easily.
My next task, should I choose to accept it is to get the 84kg wood botherers bandsaw out of the back of my van and into my new shed. Jock strap, cricket box and weightlifters belt might be needed on this one. Not a lot of hand grip on it. The four new casters I found in the garage will have life as a trolley for it as I know my limits. I think!Thanks, that's encouraging to hear.
further advice to say if your paying 2 burly ladsBit of an odd one, this. My house in Sheffield has a cellar (one of the reasons I bought the house) and in the cellar there is a stone table/slab standing on two rows of bricks. The slab measures 1.25 m x 0.8m x 50mm and by my calculations weighs around 100kg. At some point in the not too distant future I want to move that out of the cellar and into the garden and use it as a garden table. It will be mounted on brickwork which will in turn be built on a concrete slab.
My question is, will two people be able to manhandle the slab up the cellar stairs, through the kitchen and out into the garden? I'm not planning on doing it myself, but would ideally find a couple of strong blokes (bodybuilders?) to do it for me. For money, obviously. There is sufficient room to get the slab out, but it's still fairly cramped and the cellar steps are quite steep.
That was broadly the plan. I intend to have the support for the table already built and mortar dry-mixed ready to add water and use.further advice to say if your paying 2 burly lads
build up the legs and when its up and out and into the garden get them to fit it straight onto the legs with cement and level it
then your only paying for a full days work for both of them it will be worth it in doing so
my other advice is build both legs into elongated u shapes as it will support better
I'm not interested in selling it, just moving it.
No, but it can be arranged...Have we seen pics of this proposed job?
no just make 2 legs with a brick out is ample enough both sidesThat was broadly the plan. I intend to have the support for the table already built and mortar dry-mixed ready to add water and use.
I was actually intending to build a brick rectangle on top of a concrete slab to support the stone slab. The size of the rectangle would be approx 80cm x 40cm.
with a scaffie plank on the steps to slide it upCertainly looks do-able. Up on end to negotiate the turn, walk it round, then ropes front & back and......HEAVE!!!
Good luck![]()
