"Fitting" components is nothing new - Rover were doing it in the 80's with the k series, the Japanese with bike engines also. Not so sure about "electronically ballancing cylinders", maybe diesel common rail stuff?A little info from some modern equipment. cranks are not matched like they used to be, I can only assume it is because of the time saved helps profits. For example, strip an isuzu and the engine components are colour coded shells, liners and pistons and the components are stamped with a relative code. They fit a different size shell or liner rather than re machining.
Engines are balanced electronically to the lowest preforming cylinder.
I am not saying its the best way but it works.
That looks pretty terminalExactly what happens - it cracks and those cracks wreck the oil film - borrowed image of a Lancia crank from some random Italian stallion forum from some time, some where.
Lancia OE English language workshop manual for my 1991 integrale mentions the steel crank is nitrided.
. How many times has the crank been ground? the guys who've done my cranks have always said that they're good for one regrind. The usual manufacturing process is that the cranks are ground slightly oversize before nitriding, then they're ground to size afterwards. This cleans up the bearing surface, covers any slight distortion, and also hits the point of maximum hardness which is (IIRC) 8 thou' below the surface. Total depth of hardness on nitrided EN40B steel is about 25 thou'Yeah thats right, common rail diesels i have experience of it with. It does not surprise me that it has been happening since the 80s, time is valuable in mass production. Ill have to have a read up on k series etc!"Fitting" components is nothing new - Rover were doing it in the 80's with the k series, the Japanese with bike engines also. Not so sure about "electronically ballancing cylinders", maybe diesel common rail stuff?
Bit of STP in the oil...no problem.I've seen some amazing footage from the Indian sub-continent, but this takes the biscuit. I love the slag hammer and the protective shield for his right hand safety sandal
I remember that when I worked on the K series production line, the blocks, liners and pistons had letter stamps to get the best match.
As the old question ‘what is accurate’?
That’s shocking!A man who helps the vicar.
its still a form of lapWell you call it what you want, we know he used a short piece of emery cloth in it...
Been going since the beginning."Fitting" components is nothing new - Rover were doing it in the 80's with the k series, the Japanese with bike engines also. Not so sure about "electronically ballancing cylinders", maybe diesel common rail stuff?
This is when engines changed from 50,000 miles wrn out, to 100k, still like new. Sure, oil development and fuel injection played a part too.It makes sense if it is financially more viable. By chance it was the relatively late isuzu engines which seemed to have this where i experienced it first. The many perkins, cummins, cat, mitsubishi etc. were not. I suppose its just at what point or for which projects each manufacturer decides to do so.
Isnt it whats basically blueprinting, like we used to do with the 70s engines to make them a bit more pokey?This is when engines changed from 50,000 miles wrn out, to 100k, still like new. Sure, oil development and fuel injection played a part too.
Having watched it all....he is going to end up like that Russian bloke! Just a red rag wrapped round his lathe and a strawberry jam on the wallI like how in all thease eastern videos everything is done on the floor and theirs always some random old guy in the background sitting on the only chair doing nothing
Life is cheap.seen the trailer planed to watch....
have u seen the one where they weld up a heavy truck front axle.....it had a broken king pin eye....
I hate to be driving that truck fully loaded when it breaks again.....
As for the guy in the background doing nothing in UK they are known as Managers. usually with a degree or two in man management.I like how in all thease eastern videos everything is done on the floor and theirs always some random old guy in the background sitting on the only chair doing nothing
When I first started with a Japanese manufacturer I was really impressed to find the different colour coded shells for the crank. Having been used to the British M/Cycle industry . One of my colleagues was racing a cb750 engined sidecar outfit which he revved to the limit plus. I asked him about the coding system. He replied " don't bother just use the brown ones it saves P*****g about with Plastigauge" . He never had any crank problems just piston failures.A little info from some modern equipment. cranks are not matched like they used to be, I can only assume it is because of the time saved helps profits. For example, strip an isuzu and the engine components are colour coded shells, liners and pistons and the components are stamped with a relative code. They fit a different size shell or liner rather than re machining.
