Its stated at 250KG but ive had 400KG on it as i turned the unloader valve inWhere did you get one of those. What's the capacity (when it's got a seal obviously) lol
If you get stuck my son uses a place where they make them to match your pattern. It's in Wolverhampton.
which was turned in 2 years ago so nothing to do with the seal going bad. Believe it or not but i found it tossed on a pile at a scrap yard
Whatever made you leave god's country and move to the North?All seals in Norwich. Send him the old and he will send you a replacement.
You can also send measurements.
If it’s non stock they can make it. I used him when I was on the doorstep and have also done so when I moved away.
I have been looking for one that will fit in a garage and can't find anything locally.Its stated at 250KG but ive had 400KG on it as i turned the unloader valve inwhich was turned in 2 years ago so nothing to do with the seal going bad. Believe it or not but i found it tossed on a pile at a scrap yard
No Bob but i will do at 7.30 in the morningMost of them will be flogging the same seals from the same manufacturer, @roofman do you know the bore size. seal internal id and width of the Teflon seal?
Bob
Sometimes you just need to ingore the distance to get your item... https://www.ebay.co.uk/itm/133828809278?hash=item1f28d1923e:g:9YAAAOSwtyFg~RdeI have been looking for one that will fit in a garage and can't find anything locally.![]()
Too tall that one mate...Sometimes you just need to ingore the distance to get your item... https://www.ebay.co.uk/itm/133828809278?hash=item1f28d1923e:g:9YAAAOSwtyFg~Rde
gotchaToo tall that one mate...
It wouldn't take much to shorten it .Too tall that one mate...
Too many savagesWhatever made you leave god's country and move to the North?
Ah Ah yours looks lower.gotcha..its identical to mine.
