grind round the edge i cant be all that hard if its mushroomingI have an old sledge hammer that has started to pein over one end.
If I cut it off obviously keeping it cool will the next chunk still be hard or is it likely to have a soft core to it
Norberts.What have you been beating to pain over a sledge hammer head?
grind the bottom face at an angle then then it willIts ex military. The handle hole has been cast at a slight angle so in use the face doesn't hit square causing the top edge to take more force than the rest.
They probably.drove stakes in at a angle so it did hit them squareIts ex military. The handle hole has been cast at a slight angle so in use the face doesn't hit square causing the top edge to take more force than the rest.
Cool. So this is a restoration projectIts ex military. The handle hole has been cast at a slight angle so in use the face doesn't hit square causing the top edge to take more force than the rest.
Im sure it can only be a casting error as having the face at an angle to the handle, regardless of the angle of what you are hitting makes the hammer very awkward to use and causes the head to bounce forwards or backwardsThey probably.drove stakes in at a angle so it did hit them square
Some were made like that.Its ex military. The handle hole has been cast at a slight angle so in use the face doesn't hit square causing the top edge to take more force than the rest.
