Cobbler
Codger bodger
- Gloucestershire UK
A Double Diamond is even better, “A Double Diamond Works Wonders” you need to be of a certain age to remember that one.Diamond is even better
Heat conductivity is not that good on printed copper … no idea why,Have it printed?
Introducing 3D Printed Copper
Markforged is excited to launch its next metal material: Coppermarkforged.com
That's the stuff we used to use! Seeing the name now it's obvious.Dow Corning was always my go to for heat sink paste.
Assume because it's because it's formed in layers rather than cast?Heat conductivity is not that good on printed copper … no idea why,
Is it not sintered?Assume because it's because it's formed in layers rather than cast?
Laser sintering probably produces smaller grains than good old fashioned casting and drawing, every grain boundary is a tiny thermal interface so the more crystalline grains in the material, the worse it performs. I'd expect there to be pores and defects in a 3D printed part too.Heat conductivity is not that good on printed copper … no idea why,
Yup but it's still being built up layer by layer.Is it not sintered?
If heat treated after sintering don't the molecules all bond together?Yup but it's still being built up layer by layer.
Camera has a temp gauge built in. Im WFH for a few days so cant test anything as of yet.So the camera can run to 40°C ambient but is overheating and shutting down?
Thinking outside the box but wouldn't you be better off trying to reflect a load of the heat away (think tin foil) since there's a fair amount of radiant heat from welding.
As an experiment can you just wrap everything bar the lense in tin foil (literally) and see if it makes a difference. My suspicion is it will.
If you've got somewhere to attach a heatsink I'd then look at possibly a heat pipe (they are phenomenally good) to move the heat away from the camera to somewhere else you can cool it? Water cooler?
Currently looking into this as one of our chaps suggested it so going to try what we have firstWhat about a Peltier cooler; this is the biggest that RS has but I'm sure there are biggers ones https://uk.rs-online.com/web/p/peltier-modules/1743123
The guidance notes pdf on that page is really interesting.
will be sending it out to our machinish to add fins, from what iv researched so far the fins need to have more than 3mm gap or in not going to workThat size block won’t dissipate that much heat once it is up to temperature… I assume you will fin it in some way? Or is the heat input relatively small ?
Iv ordered this from RS to try with a cheap aluminium heat sink iv gotI suppose that rules out adding a fan to force some air over the heatsink?
it self heats to 40 and when we run the machine it reaches 86C then the picture disappears, currently takes 20 mins to not effectively workCan you put a thermocouple on the part that's shutting down, log the temp and see how hot it gets before/after the welding starts?
I.e. is it mostly self-heating, or infrared from the welding that's the problem? The answer to this will determine the best way to attack it.
As mentioned earlier, at normal heatsink temps convection dominates over radiation. But if there is strong external IR from a welding arc or similar, a highly reflective coating on the heatsink might help. Gold (even a fraction of a micron of plating will work) is one of the best IR reflectors you can get. The usual black heatsink finish will make things a lot worse in this case.
what are the heat pipes filled with, air or liquid?it being flat is most important, polishing not past like a 400 grit finish - it generally makes it worse after that.
Yes, big difference on thermal compounds.
If the interface is small is it possible to incorporate heatpipes instead?
our laboratory is MK, feel free to pm mewhere are you roughly?
yep currently have these on the shelf waiting for me to get back to work and build one upMight be an obvious question, but have you looked at CPU and GPU heatsinks?
They are available in a range of different shapes and sizes and they are pretty efficient and well optimised.
Might be a lot easier to find one that is close and adapt it rather than reinvent the wheel.
any links to a heat pipe? Fan is on my desk at workMaybe a heat pipe type cooler and a fan.
wont workHave it printed?
sounds like you've got one of the cameras that films the weld in Infrared and gives a real time idea of penetration, heat input and heat affected zones?
www.tpsweldtech.com
see aboveHeat conductivity is not that good on printed copper … no idea why,
see aboveLaser sintering probably produces smaller grains than good old fashioned casting and drawing, every grain boundary is a tiny thermal interface so the more crystalline grains in the material, the worse it performs. I'd expect there to be pores and defects in a 3D printed part too.
will ask next time Im down at quantum in mk. We use them for heat treatingIf heat treated after sintering don't the molecules all bond together?
A low boiling solvent and a metal "wick". The solvent evaporates at the hot end, flows to the cool end and condenses, then is drawn back to the hot end. Because there's actual mass transfer, the thermal conductivity can be far higher than solid metal (250 times better according to wiki!). You'll still need a heatsink on the heat pipe, a heatpipe alone will eventually reach equilibrium and work no better than a copper pipe.what are the heat pipes filled with, air or liquid?
Im gonna run with what I have and try the ali and CPU fan, then the copper should be here and I can get that machined to spec, then look at the cooling tubes as there arent very expensive in the RS catalogueA low boiling solvent and a metal "wick". The solvent evaporates at the hot end, flows to the cool end and condenses, then is drawn back to the hot end. Because there's actual mass transfer, the thermal conductivity can be far higher than solid metal (250 times better according to wiki!). You'll still need a heatsink on the heat pipe, a heatpipe alone will eventually reach equilibrium and work no better than a copper pipe.
https://docs.rs-online.com/d08f/0900766b813eb684.pdf looking at the tech document im not entirely sure which one to go forA low boiling solvent and a metal "wick". The solvent evaporates at the hot end, flows to the cool end and condenses, then is drawn back to the hot end. Because there's actual mass transfer, the thermal conductivity can be far higher than solid metal (250 times better according to wiki!). You'll still need a heatsink on the heat pipe, a heatpipe alone will eventually reach equilibrium and work no better than a copper pipe.
Iv ordered a 4"x2"x4mtr piece for £71 will try a few different designsCould a forge-ist help you?
10 Kg / £60 of scrap bright copper wire would give you a nice, pure big block to machine down.
Ive got a small lump of pure silver I made a water cooling block with years ago. The specific heat is about half, it performs better than the numbers would suggest.In that case, silver has a slightly better thermal conductivity than copper...![]()
