here https://www.etsy.com/uk/listing/111...uiTjHAf89PQQQFUjr5-SunW_EsuZM6oBoC-VQQAvD_BwE easy enough to make out of mild steelI need to make some up that will fit in this gap.
The plan is to weld some arms onto a cheap pair of pliers for the hinge.
Is mild steel sheet adequate? Everything will be hot, I do not want it to sag and drop out.
NoooThose both look good. Do you use the same for pouring?
Mine will weigh 2.5kg full of ali.
Half hour holding scraps against cruicible, no plan yet.. Did I mention it needs to be small for storage?
A big pair of stilsons sounds like you a big pair of something else lolI'm gash and stupid, I used to lift it out with a big pair of stilsons onto a ring of rebar on a handle to pour.
