They're for seals as far as I know, not suitable for roller bearings to act directly on. Like a Speedi SleeveSKF do an inner repair ring, you could grind/turn shaft to size and press one of those on. https://www.skf.com/uk/products/ind...inner-rings-non-directionally-ground-raceways
Bob
Yes wrong link Brad, what I was getting at is you can get an inner track for a needle roller, so may be easier to grind/turn the shaft and press one of those on, https://www.bearingsrus.co.uk/nao25...MI5qeW0JOi9QIVCeDtCh0wLgmjEAQYASABEgItkPD_BwEThey're for seals as far as I know, not suitable for roller bearings to act directly on. Like a Speedi Sleeve
Yes yes that would work. Grind shaft smaller and then use smaller ID bearing. Obviously depends how much meat on shaft there is.Yes wrong link Brad, what I was getting at is you can get an inner track for a needle roller, so may be easier to grind/turn the shaft and press one of those on, https://www.bearingsrus.co.uk/nao25...MI5qeW0JOi9QIVCeDtCh0wLgmjEAQYASABEgItkPD_BwE
Thanks for all suggestions, this is water damage.SKF do an inner repair ring, you could grind/turn shaft to size and press one of those on. https://www.skf.com/uk/products/ind...inner-rings-non-directionally-ground-raceways
Bob
I guess I could look into a bearing with the same outer but smaller inner, and grinding that to size.Thanks for all suggestions, this is water damage.
@8ob has my preferred option, the critical bit is the wide bit, where the needle roller runs. Tbh, it's running quietly, but I haven't loaded it up yet. I might consider making my own ring, hardening it and then shrinking it on - what could go wrong?
NAO25x42x16 SKF Needle Roller Bearing With Machined Rings With Flanges, With Inner Ring 25x42x16mm Needle roller bearings without an inner ring are an excellent choice for compact bearing arrangements if the shaft can be hardened and ground. Eliminating the need for a separate inner ring enables a larger shaft diameter and a stiffer bearing arrangement. Axial displacement of the shaft relative to the housing is only limited by the width of the raceway on the shaft. By machining the shaft raceways to the appropriate dimensional and geometrical accuracy, it is possible to obtain bearing arrangements with heightened running accuracy.
(Quote from the site @8ob pointed to). This is 2 inch dia or so, int 30, and strength is important. The needles in mine are tight packed, the more the better I say?
you would have pitting with water damage and that dosnt have itThanks for all suggestions, this is water damage.
It's water damage. I may be stupid, but not that stoopid...If we're talking about the larger OD with the lines on it that's definitely corrosion damage where the rollers have been staic over time, and somewhat damp.
Now, that wasn't someting I checked, but assumed for maximum strength it would be rollers running on the shaft.Isn’t that the inner sleeve, of the bearing, and removable?
Would it not be better to find equivalent taper roller or double angular contact from timkenThanks for all suggestions, this is water damage.
Hmmm, will have to pull it again.
No Brad, not enough room for anything other than a needle roller..Would it not be better to find equivalent taper roller or double angular contact from timken
Yes, and there is also a step in diameter - why would that be there otherwise?Of course, I'm agreing with you.
I'm also thinking that Morrisman has hit on something there as the joint line seems to serve no purpose except for being a shoulder for the inner race to sit against.
What takes the axial load?No Brad, not enough room for anything other than a needle roller..
