Gragson
- Bucks
Downstairs rads have been taking ages to heat up and have gotten to the point that unless I turn the hot water off they don't heat up at all, seems to have gradually got worse but turning HW off seems to kick it in. Upstairs all hot either way.
The 3 way valve I replaced about 8 years ago and the programmer at least once, maybe twice, the Grunfos pump was replaced about ten years ago.
A mate "who does a bit of plumbing" reckons that the rads/pipes need a flush - he is not a heating engineer by any stretch! Half the rads are newish, 7 upstairs 7 downstairs.
The house was extended about the same time the new pump went in, but not sure if it was matched for extra rads.
I'm thinking an additive and drain down won't hurt, unless it makes things worse! But also suspecting the pump might not be up to it?
Is there a an online tool where you can put the data into and it spits out what your pump should be?
