Is that one of those modern ones that uses electronics to conjure up some "magic" result? I think the old-fashioned load meters that connected a short length of very thick nichrome or stainless wire across the battery to drain 100A while measuring the voltage. There are cheapy versions on ebay for £12-15. I would guess that anything that really tells you the CCA will be expensive.You are better off getting a battery heath type meter that can tell real CCA compared to spec.
£30 ish.Is that one of those modern ones that uses electronics to conjure up some "magic" result? I think the old-fashioned load meters that connected a short length of very thick nichrome or stainless wire across the battery to drain 100A while measuring the voltage. There are cheapy versions on ebay for £12-15. I would guess that anything that really tells you the CCA will be expensive.
Those green light don't mean a great deal. SadlyThanks,no solar charger,the green indicator is glowing,so maybe it’s been in storage.ill try the crank test.
Well, I don't suppose, by any remote chance, you can explain how such a cheap device can measure a battery's CCA, handling a current of 100's of amps? I think that's a test you'd need a well-equipped laboratory specialising in car batteries to do. A plastic box with flashing lights means nowt - remember those two guys who went to jail for selling "explosive detectors" which could not actually detect a "bottom burp"?£30 ish.
These testers are quite cheap (I have one) and do a superb job. You need to understand the results you get from the meter, but it is not rocket sciencethe old-fashioned load meters that connected a short length of very thick nichrome or stainless wire across the battery to drain 100A while measuring the voltage
https://www.hioki.com/global/learning/usage/resistance-meters_2.html explains how they do it, although that page isn't specifically for lead acid batteries.Well, I don't suppose, by any remote chance, you can explain how such a cheap device can measure a battery's CCA, handling a current of 100's of amps? I think that's a test you'd need a well-equipped laboratory specialising in car batteries to do. A plastic box with flashing lights means nowt - remember those two guys who went to jail for selling "explosive detectors" which could not actually detect a "bottom burp"?
They keep your hands warm!
I think 8 volts is too much of a drop, modules coming on line at 8 volts will register a fault, even 9.5v is a bit too much of a drop,Connect a multimeter across the battery terminals, then crank the engine and watch the voltage, a good battery will drop to about 9.5 volts min, possibly 8 volts under load, when the key is returned the voltage should return to 12 volt virtually instantly.
You also have to listen to the engine cranking to hear if the rotational speed is held...
The new electronic type battery testers are not worth a rub imho....![]()
This maybe so for modern stuff, but we have been talking about battery volt drop, I trained on Ford D series, Cargo's, Traders and Transcontinentals, plus the odd Commer 2 stoke and Atkinson Borderer. This ECU lark is OTT.....I think 8 volts is too much of a drop, modules coming on line at 8 volts will register a fault, even 9.5v is a bit too much of a drop,
