hello, im going to be setting up a spray booth in my shed, and need some advice on filter material for both intake and extraction.
My shed is split into 2 areas, the spray room and the entrance area. entrance area is 2.4 by 1.4m.
the "spray room" part of the shed is 3 metres by 2.4m
my extract fan- im going to be using a 12 inch RVK duct fan, which will be boxed outside of the main room to extract. this will be attached to about 10m of flexible ducting and will be vented outside. the fan box will be approx. 0.5m square.
i will cut out a hole from main spray room to entrance area, approx. 400mm by 400mm which i was going to put the filter material over.
im not sure what material to use, some say the accordian style stuff, others the fibreglass type, or the media pad type or even the pre formed panel filters.
intake will be passive, but will also need to be filtered.
anyone got any advice on this, if it will be suitable, or what to use, will be much appreciated.
cheers
cheers
