Dieselman 63
Forklift Certified
- Wellington, New Zealand
Here I’m doing a ‘dry’ run of the lifting gear. The handle will be welded back onto the piece that for some reason was cut off. I have a suspicion it was cut because of alignment with the piece above it which requires a locking pin. I’m going to cut some of the bushing off so the weld doesn’t interfere with operation. It’s all gone quite well, though. Had to straighten a few bits in the vice. You can see how the PTO shaft would make fitting this piece impossible with the long handle.
two for each side, plus one that went on the PTO box.
Do they do a different version?
