Hood
I am obsessed.
- Carnoustie, Scotland
I would need bigger than that I reckonAre you going to randomly stick them on the **** of your strides and the seat to keep you on the bike![]()
Oak "stick".................................took this oak stick out from behind a garage block the other day. ..............................
View attachment 325434View attachment 325433
Its a shame some of you woodists don't live a bit closer, took this oak stick out from behind a garage block the other day. Fair few bowls and seat tops in that.
Or you designe and build a wood oven to dry it out for us all.It would be worth my fuel to hook up the trailer and pay you a visit @8obwaiting the 10 to 15 years while it dries out may be a problem though!
I did think about that, I watched a Canadian chap on YT make one from an old upright freezer and incandescent lamps.......Or you designe and build a wood oven to dry it out for us all.![]()
Wow, they are beautifulWhen I had the Woodmizer sawmill we used to slab everything to 50mm ish, thats good to go in about two years if you keep it under cover. Its about an inch per year so bigger beams do take a long time, that said most guys like to work with green Oak
I am lost for words!! What do you do with the stuff now if you no longer have the mill?Wow, they are beautifulI am lost for words!! What do you do with the stuff now if you no longer have the mill?
The mill went because it couldnt cut anything bigger 32" diameter, the gear on the trailer was about its limit, the stuff in the lower pictures are typical of the size so we either needed to get a much bigger mill or stop so I got rid of it. If a huge mill turned up for the right money I would get back into it, for the meantime I sell it on.
Some of these bigger boards had to be cut using a chainsaw mill, thats no fun
I've also done some monitoring, I fitted a temp sensor to one of my fresh air vents to do some calculations. I have got a heat recovery ventilation system where the whole houses air is run through a heat exchanger, which heats the incoming air and cools the outgoing air. Doing some math I get that the heat recovery is 60-65% efficient, which is less than I had hoped. The ideal range is in the 80% range.
I am going to have to do some fiddling of the system. I will start with cleaning the heat exchanger and try and swap in new filters. It's a sensitive system apparently, the fresh air vents (placed in bed rooms, livingroom, sauna) have to be in the right proportion to the extracting vents(kitchen, mudroom, bathrooms), and the total result should be a slight under pressure in the house. I got the original plans where it's all calculated so I can use that for a reference, but I would need an aneometer to diagnose it properly.
