Some ok advice so far. But lead is a cumulative bio burden. By the time you know something is wrong it’s too late.
first signs are numbness and drop of the extremities. Bit more and it affects your brian
”mad as a hatter’ comes from pressing animal pelts with molten lead for hat making.
probably a few folk that have already been affected. It has a very long half life ........l
easy to experience a big dose, even with simple well run home experiments
lead isn’t something I would play at home with
I thought it was mercury or at least the fumes given off it that made the hatters go mad. Not a chemist nor was I very attentive at school, so could be wrong.
Apologies. I’ve got my metals mixed up last night. It is mercury that’s used for hat making.I thought it was mercury or at least the fumes given off it that made the hatters go mad. Not a chemist nor was I very attentive at school, so could be wrong.
Last time I melted any lead was on the then girlfriends mum's kitchen stove, in one of her saucepans, it worked fine tho I did sense a bit of disapproval as I recall..![]()
your close enough to give a dire warning with lead parmApologies. I’ve got my metals mixed up last night. It is mercury that’s used for hat making.
my bad
The strangest place I’ve found lead is in the varnish used on parquet flooring in old buildings.your close enough to give a dire warning with lead parm
lead is bad enough but painted lead and lead with laquer is bad enough with wheel weights there the ones you have to watch out for bad fumes
lead piping is renowned for being painted in houses if they still have it installed
lead wheel weights do have laquer on them
lead flashing has other additives due to the atmosphere more so old used lead
id advise myself to do any lead melting outside not inside once in the body it never comes out and yes you can die from lead poisoning
Lead poisoning, also known as plumbism and saturnism, is a type of metal poisoning caused by lead in the body. The brain is the most sensitive. Symptoms may include abdominal pain, constipation, headaches, irritability, memory problems, infertility, and tingling in the hands and feet.
What is an example of lead poisoning?
inhalation of lead particles generated by burning materials containing lead, for example during smelting, recycling, stripping leaded paint and using leaded aviation fuel; and. ingestion of lead-contaminated dust, water (from leaded pipes) and food (from lead-glazed or lead-soldered containers).
our old housesThe strangest place I’ve found lead is in the varnish used on parquet flooring in old buildings.
I once melted aluminium in a beans tin on an open fire, at a bike rally. Then I scraped a cross shaped mould in the ground and cast a rather rough crucifix.You can melt lead in a saucepan on the oven. I melt mine on a little camping stove.
If you stick a pan in a fire, you can end up boiling lead and that is crazy dangerous.
It’s a big issue in restoration of old buildings and painted surfacesour old houses
has it in everything
paint
vanish
stone posts, gate posts
you still find lead gas piping still in use today
lead water pipes
you can get fumes off of lead to copper piping when using a blowlamp more so in old toilets
I’m not aware of any treatment for lead poisoningThis originated from the hatters that used mercury as an adornment for certain fashion hats for the ladies.
Of course, Mercury and lead are both ‘heavy metals’ of high atomic mass. My examples of water and liquid lead is far more appropriate to Mercury which is, of course, a liquid at room temperature (which luckily boils at over 350 degrees Celsius). Mercury posoning is almost irreversible, whereas lead in the system can be treated with drugs, at least to remove it from the bloodstream.
It can be done quite safely, lots of folk do it.well as it so dangerous to melt lead in a workshop ill leave this project, mite just build the stove alone.
thanks folks for the info![]()
I didn’t know thatFrom the net (mayo clinic info)
Treating higher levels
For more-severe cases, your doctor might recommend:
I used to work in the precious metal recovery industry. Blood lead levels of some operatives were requiring removal from that part of the job and a couple were really high, so needed extra treatment. I was only at risk from Platinosis - I kept well away from the silver recovery side of the operation.
- Chelation therapy. In this treatment, a medication given by mouth binds with the lead so that it's excreted in urine. Chelation therapy might be recommended for children with a blood level of 45 mcg/dL or greater and adults with high blood levels of lead or symptoms of lead poisoning.
- EDTA chelation therapy. Doctors treat adults with lead levels greater than 45 mcg/dL of blood and children who can't tolerate the drug used in conventional chelation therapy most commonly with a chemical called calcium disodium ethylenediaminetetraacetic acid (EDTA). EDTA is given by injection.
