Munkul
- Cumbria
I'm surprised that you're OK with that setup... I'd have thought you'd be modifying that rough looking bottom tool to accept a length of 60x60 X form tooling. That way would make it more flexible too, as you could segment top and bottom tools properly... It would transform it from a toy into a proper mini brake, and air bending would be accurate as long as you're centered.I bent up some 60mm x 5mm stainless today as inserts for it, it reduces the width of the V to about 25mm from the 33 as delivered, it lets you bend a tighter radius on thinner stuff and also lets you bend shorter distances between bends. Might even make more up to reduce the V width more.
I still have to dress off the tops of them.
