The log burner in the kitchen is on 24/7 this time of year. Its a small Villager C model - so cheap and no frills but works fine and keeps the whole house warm.
It draws well. Doors closed and you can get it roaring in seconds with the damper open and vents at the front open. This last week though, if you open the doors with the flue damper open smoke will waft out of the opening. Last week it would be pulled up the chimney as long as the flue damper was open fully. Close the doors and its fine and it draws well (will pull tissue and hold it against the front vents).
I swept it at the end of last season. The stainless liner seems good visually looking through the inspection hole on the register plate. The brushes run up fine.
What causes this? It was fine till a week ago. We haven't sealed the room more or anything. Is it true it could be the weather? Wind has changed direction multiple times since it started doing it but it did coincide with the high pressure that seems to be hovering over the UK.
