I am guessing these cables will be hard to cut and terminate? Why are they so huge for 400w? Armoured I assume?
@brightspark or any other sparkies
advice most welcome.
Will I have any problems using an LED high bay on the same circuit as some of these?
That will be fine, discharge lighting has high initial loads so the circuits will be or should be well over the top for LED stuffWill I have any problems using an LED high bay on the same circuit as some of these?
Good thinking Batman!Can you follow the cable back to ground level (to a junction box / fusebox?) so you can inspect it up close rather than guessing from a distance? (hope that makes sense)![]()
