northwest
- Manchester UK
The other job I was on today was sorting out the tray for the CNC Lathe, now that it is going to be bench mounted and without the benefit of the stand I set to and made a frame from 40mm Box for it to sit on and give the tray some rigidity, I also welded up a couple of holes in it and this made it buckle quite badly so I made double sure the box section frame was square and flat then welded the tray to it, came out well in the end, at the powder coaters now:
Used my pal's job as a work table, one thing I know his work WILL be flat and square so a good base to work from:
