I’ll probably be down on Sunday, I’ll drop you some more inStarted to make a cage for the Soil pipe at a local Scout hut. The scallies come along and kick it to bits covering the field in waste so not good, I am trying to put something around it to protect it. I am going to hammer a couple of lengths of rebar into the ground and weld it to them, we will see.
It needs some tabs for anchor bolts welding on:
I can get power to the area so I will take the set and use a couple of those nice Fincords I nicked from @Tinbasherdan to weld the RHS on and the rebar "legs" They are nice rods Dan. Bring more!
Some swarf
Only one cutter was harmed in the making of the swarf (pesky clearance/retraction heights in F360!), and it fits.
Just need to countersink the bolt holes from the opposite side, trim the two oversize sides, machine up the bars for in the slots, and I might get the first servo motor bolted onto the big lump of iron that's been sat in the workshop for the past year or ten...
First I made a top from some 5mm aluminium and bolted it to the top of an old stainless frame I had so that I had a place for the, newly acquired, mini press brake.
Here you go.C'mon. Where's the link, for the weak-willed amongst us?![]()
I then adapted the quick and dirty rod bender I made years ago for a specific job so that I could make a U loop in some 8mm stainless. The adaption was to put a socket over the bolt so that I got the correct radius
Worked well, really should make up a better one some day.
I then bent some 60mm x 5mm 316 stainless in the new press and welded the loops to them.
Next up I went to cut a rack on the plasma but the bleeding gaskets went in the compressor again so I had to make some more. Found some carboard and cut them out.
Compressor now running again so I was able to cut the rack, this time I cut with a higher current and it cut better, even leaving the centre of the small 'a' unlike previous attempts. I then tried to bend the tabs but that didn't go great, the bend happened at the slots rather than further in, I was kind of expecting it but....
Not sure how to overcome the problem, possibly having a backing bit of metal to support as the fold is done would be the way but I am not sure if the brake will be good enough as it is only supposed to do 4mm aluminium at that length, we will see.
Before I headed home I soldered up a mast head light, it is a local restaurant that has it for a display piece but people keep prodding it and the solder gave way and the glass fell down. Wasn't making any promises and actually didn't think I would make anything of it as I don't have the right gear but I managed to get it back together with a soldering bolts and some solder, not the neatest but not any worse than the previous repairs that have been done.
I presume you were really meaning this one though
Hydraulic sheet metal folder bender press brake 305mm 12" | eBay
The S12 R/T hydraulic press brake has a folding capacity of 305mm (12"). This machine will fold 5mm thick steel up to 100mm, 3mm thick steel up to 200mm widths and 2mm thick steel for up to 305mm widths.www.ebay.co.uk
Aye seems pretty good for what it is, time will tell but it made short work of the 5mm stainless.What's it seem like, quality wise? Decent bit of kit?
Dog doesn't let me through the week as he needs to get to work so have to use the van.good excuse to go get the bike then, you could get a full roll in they paniers nae bother.....![]()
