DAPPH
as dyslexik as I'm daft
I have a precision ground 1"lenght of drill rod that perfectly fits through two pulley sets , two pulley driving dogs as well as two sintered phosphor bronze bearings that the drill rod shaft is mounted in .
I want to change the two phosphor bronze bearings into a four roller bearing support.... two rollers on each former phosphor bearing support .
My problem is that the 1" drill rod will not be an easy hand push for to get the roller bearings in the right place on the drill rod shaft . If I turn the drill rod down it will be a sloppy fit in the pully's & the driving dogs .
I've had a quick look at bearing suppliers but cant find anything that is a tad bigger than an inch dia that will give me the sliding fit I desire. I E . 1 & 1/64 ID or 26 mm ID .
I do have two bits of 2 Inch dia by four inch long precision round bars that I can make the roller bearing carriers from .
I don't want to use a new set of phosphor bronze bushes as they will still require reaming as a pair ( don't have the reamers or four inch or more long cylinder cutting bars & lubricating at the start of each lathe turning session & the leaning forward to do it is getting harder & harder for me due to progressive spinal problems making life difficult..
Anybody got any suggestions I can explore ?
