if it was important there would be a spec to work to ,, so as I mentioned , get a name and keep records , its an **** covering exercise , with a tight root and a cap it gives you two bites at the cherry also .I can only assume this is non critical
Bob
Hi Kieran, what spec of rod you using, Lo-Hi's and, are you with Dales?Quick question, for a 6mm fillet on a rig could I do that in a single run or multi pass?
Cheers
depends if the plate is a close fit and how clean the prepYeah sorry, MMA, all the amps I could ask for and it’s welding a saddle to the deck for a vent line going outboard. Probs going to use 4mm rods on the deck and 3.2’s for the bracket going outboard that’s also a 6mm fillet.
Pretty much having a brain fart and wondering if one run will be fine or multi pass it.
Cheers
