Dieselman 63
Forklift Certified
- Wellington, New Zealand
Parkinson vice slipping.The spring is for a Record, and doesn't fit well with the Parkinson nut, but does hold. Fixing it is in the pipeline - I'll try to find a replacement, or maybe make one.
Interesting that the tang on your adjuster nut is bent out to grip the spring hook, mine isn't.
I will try to source a replacement half nut, as I was also thinking it looks worn.
Thanks for the guidance.
Do you know the original colour for Parkinson vices?
My research so far is that the original red paint mellows over time to the rich dark red yours has, but I've not found any references to what the original colour was.
Those jaw ends could use a bit of smoothing up ?Record 36 done. A beautiful early steel one, very rough casting, still works well. Slides easily and qr grabs nicely.
View attachment 322534 View attachment 322535
Kind of reminds me of a neighbours mouth, she looks like she's chewing a wasp.
Several No 6's on eBay priced between £60 and £130, while the No 7 can be had for £400 with delivery.Hello all
I've currently got a hankering for Record no 6/7/8 (one of them not all.. well currently anyway)
Is there any way to date these/ get an idea of roughly when one I might look at was produced? Does the patent no' being written on (as per Dieselman 63's No4 & 00 )apply to these models too ? Are there any particular features of early/ mid production 6/7/8's vs the later ones to look out for ?
Many thanks
I have now finished my Paramo no51, when i was taking it apart it astounded me how good the quality of cast was, there was very little sign of factory grinding at all. The bar keep and the QR trigger are made of Brass! which in my mind is a bit of extra quality the other vices don't have. The QR spring was heaven to put back with the right tension, no castle nut adjustment required. Everything was reused except for the split pin. This is now my keeper woodworking vice, amazing quality and smooth as silk.
I have tried to date it, i note on the top of the static jaw is stamped "4" and "1/52", i am thinking the later was for Record's 52 1/2, if this is correct it could be one of the earliest production runs when Paramo were still forging for Record, when they stopped forging for Record i am not sure.
View attachment 322983 View attachment 322984 View attachment 322985 View attachment 322986 View attachment 322988 View attachment 322990
Does having brass pieces suggest quality or is bras easier/cheaper to cast? Aesthetically, it looks better, but is there another reason.
Steve
Just a thought. Could it be possible that some vices in the past were made for the munition manufacturing industry with regard to using dissimilar metals, because of the remote possibility of a friction spark creating an explosion.
