Thanks RichardHe took them with him on his way out.
Hello Johnboy303,Ok, ok, I know its hard for some of you to understand this and I really couldn't care what Kemppi UK have to say, but come on what's so hard to understand that I am running a three phase machine on single phase (without any type of conversion setup)
I suppose you don't believe I run a three phase lathe on single phase through a VFD either! Seriously just because you (and Kemppi UK) haven't see or heard of this being done doesn't mean I'm a liar or I don't know what I'm talking about. Get a grip people and calm down, just because you don't know something and have never heard of it doesn't mean it is a figment of a person's imagination
I'm not telling people to do this, just explaining that it can and has been done and people are doing it with this machine...By the way notice that super noob said the guy selling the machine was doing it also, well there's at least two of us in the whole world doing it, but I'm sure there's more
One day when I have time I'll take a video of my machine a Kemppi 2500W (notice the W, yeah it's water-cooled and it has a Pulse panel also running on a 240 volt 50 Hertz single phase power supply and me welding with it, on second thoughts why bother, you still won't believe it I'm sure
Also they didn't make a single phase 240 volt water cooled TIG machine 15 years ago when my machine was new, so I'm not confused over what machine I've owned for the past 15 years, but anyway thanks for the help Richard!
Cheers Johnny from Australia... You know Australia, it's down the bottom of the world where single phase rules supreme and we ride kangaroos to work![]()
Hello.Hello Johnboy303,
Can u plecase tell me how to make the conection If i want to use this ar home at 220V.Do u have a video or something?
Thank you!
Hey fella, thanks for the excellent explanation.Hello.
You may notice this is my 3rd post here.
I hope it helps you out.
If you want to run one of these machines. And we are ONLY talking about the mastertig 2500 (w) or it's blue clone. The bigger 3500 machine does not have voltage selection so will not operate at the lower voltages.
Why the voltage selection on a 3 phase machine. To meet global or international use and supply.
Different countries produce power at different voltages and frequency. The frequency is not a concern here as long as it is somewhere between 50 and 60 Hz.
220v 3 phase is found where the single phase supply is 110 or 120 volts. Such as the USA..
380 and 440 v is down to different phase configuration and or different generation systems elsewhere.
The correct voltage range...
It must be known and pre selected with the switch behind the control panel.
It should be checked before connecting the machine to a new source.
It must not be switched while the machine is on
The machine is fitted with a 4 core flex.
1 of these cores is the earth (protective earth) and should be green and yellow.
This MUST be connected to earth of the supply to ensure protection in a fault condition.
The other three wires are phase wires L1,L2, L3. the colour does not matter for this as we may not know where they are connected internally.
I do hope however that there is no BLUE wire as this can lead to a dangerous confusion caused by the change of assigned wire colours. Blue used to be a phase (live) colour, but is now assigned to neutral. This machine However has no neutral wiring.
Take a 16 amp or 32 amp single phase plug. Rated for 240 volts between pins.
Connect the earth wire to the earth pin.
Connect one phase wire to the neutral pin.
Connect the other two phase wires to the live pin.
Ensure there are no stray strands of wire to cause shorts and everything is secure.
Ensure the voltage selection is correct and you have not more than a 20 amp breaker protecting the socket you are going to use.. 16 amp if using a 16amp plug.
Connect up and switch on the welder.
If it does not power the controls up, you will need to alter the phase wire connected to the neutral pin inside the plug.
Swap the wire in the neutral pin for one of the other phase wires. And try again. This should be enough to make it work.
If you don't understand the importance of getting the wires safely and correctly terminated, or why the breaker needs to be less than 20 amps, or that there may be internal mods and a neutral added to the machine then do NOT DO THIS.
YOU CAN EASILY KILL PEOPLE/YOURSELF, CAUSE FIRE OR AT VERY LEAST DESTROY THE WELDER.
only use a single phase plug on the machine. Clearly mark the machine for single phase use only as it is setup.
If some smarta*** opens a 5 pin plug and sees the way it is wired to test the single phase theory out.. and rewires it for you, without changing the voltage switch you can kiss the welder goodbye.
If you run it at full power on single-phase you will melt the main on/off switch, the voltage selection switch, the diode bridge and possibly other components.
These machines have no input protection other than a competent installer and the correct breaker on the socket.
Good luck.
As a side note. It should also be possible by implication to run these welders on a 2 phase supply just as above. But why would you only use 2 phases. Beats me.
If this breaks forum rules suggesting a potential dangerous mod please rest assured that it is only the competence of the modifier that is the danger. As is always the case. I won't be offended if it needs deleted or redacted.
Alister.
